Liked 19 Times in 10 Posts
I am wanting to know about plumbing a Moroso Accusump with electric valve.
Can ball valve be eliminated? can electric valve be installed on oil filter adapter? The Oil line would leave accusump and be routed to electric valve attached to oil filter adapter thank you in advance |
Liked 299 Times in 48 Posts
We run our accusumps with the electric solenoid mounted right to the accusump, and the exit line feeding right to my remote filter adapter. It works flawlessly, I highly recommend it. This does eliminate the ball-valve too, yes. Our solenoids are connected to the ignition switch, so they intentionally push a few quarts of pressurized oil into the motor each time I am about to hit the starter. When the motor is running, the pump pressure stabilizes and it pushes the couple quarts back into the accusump and I had a fully primed engine before every start up.
Liked 10,691 Times in 2,227 Posts
Mike what electric valve do you use? Thanks
Hey Larry - We use the kit from Moroso in the link below. It works really well! It shows that they are out of stock, but I would think a little Google searching may bring up whatever the source is for that solenoid and it's just a pipe nipple that connects it to the accumulator container too.
https://www.moroso.com/solenoid-valve23905/ |
#5 | |
Liked 1,579 Times in 582 Posts
https://www.cantonracingproducts.com...or/valves.html |
Thanks to both of y’all.
