Ok, we got the air/fuel ratio installed and I'm getting a reading of 11.2 or so on the O2. I'm assuming this means the car is too lean? I have heard we were looking for mid 12's on this reading. Two part question, am I correct that it is too lean and do I just adjust fuel pressure for this or fuel and timing? This is a 4 cylinder turbo ford combo stocker.
#2 | |
Liked 564 Times in 66 Posts
Oh, and to some extent it is better to be a little rich than lean...but you knew that. Bill |
Liked 11 Times in 8 Posts
You didn't say when you're seeing this AFR. Under load, Idleing? 12's under full load on a turbo setup sounds a bit on the lean side, however I'm surew that there are a few turbo racers on this forum that can help. Joe
Joe Buchanan SS/BX 3117 |
I have only tuned street cars with turbos, but those won't live long leaner than 12.0-1.
Mid elevens works well, and leaner shows very little power increase with a turbo. 12.8-1 & 13-1 are normally aspirated numbers.
Ed Wright 4156 SS/JA |
11.2 A/F in a turbo race motor under load is ok. Better too rich that too lean, especially a turbo engine! You would be surprised how quickly those pistons go from being a solid to a liquid! Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 D2 National Open Stock Champion 1981 D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 4 Times in 2 Posts
Marc, shot you a message on FB. Get back at me!
Lee Norton - N229 STK IHRA H/FIA - NHRA O/SA RacerTees.com |
Liked 15 Times in 2 Posts
that's the question - how much boost? My car drops more than 2 whole numbers from 12.x staging to 9.x @ 18 lbs boost.
Why?
