Old 10-09-2008, 07:11 AM   #1
bobby
bobby's Avatar
Default What are the chances
of building a stocker out of a 79 Trans Am with a 403 Olds motor in it. found one around the corner from my house for sale the other day. Looks to be all original with minor cosmetic work needing to be done.
bobby is offline   Reply With Quote
Old 10-09-2008, 07:32 AM   #2
SSDiv6
Liked 1,582 Times in 582 Posts
Default Re: What are the chances
The 403 Olds is a very competitve engine when built properly. The downside is the weak block with its thin block casting and the open webbing in the mains.
When building one, I would suggest Bob Dennis in Alabama.
Old 10-09-2008, 09:13 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
Dave Boertman runs a '88 Firebird with a '79 403 in GT/JA . He drops to GT/KA with the same combo. I noticed a few others running the 403 Olds in GT classes.
I noticed in Nitro Joes stats that in I/SA there are 2 '79 Firebirds listed. Travis Stargell & Dennis Dunlap run about 1 second under. They are listed as 403 Pontiac @ 185 HP factored to 288. I would bet these are 403 Olds. Same as Jason Biscay in a '78 Delta 88 in I/SA. The big car carries a 284 HP factor & is about .7 under in I/SA & J/SA.
Bobby, didn't Tony Crowell run a 403 in a 70'ish Camaro in SS/GT a couple of years ago in Div. 4?
Like SSDiv6 said, Looks like it will work. Big engine, big carb, small stock cam & underrated. Some of the good points of a good stocker combo.
Adger Smith (Former SS)
Old 10-09-2008, 09:46 AM   #4
SSDiv6
Bill Kost (RIP), had the fastest Olds 403 in the country and held many records in Stock Eliminator for many years. Boertman runs a Bob Dennis engine on his SS/GT. Also, Rock Running uses the 403 engine in SS/GT.
Old 10-15-2008, 08:17 PM   #5
Robert Swartz
Robert Swartz's Avatar
Read this thread with some interest. I also know where a 79 Firebird, w/o engine and transmission, resides at present. I looked up the available engine combos:
These are the engine options offered for the 1979 Firebird:
Engine Options
V6 231, "A" Code - 105hp
V8 301 "Y" Code - 140 hp
V8 301, "W" Code - 150 hp
V8 305, "H" Code - 133 hp
V8 350, "L" Code - 160 hp
V8 350, "X" Code - 155 hp
V8 350, "R" Code - 160 hp
V8 400, "X" Code - 220 hp
V8 403, "K" Code - 185 hp
Are one of the 305/350 engines corporate Chevy options? Badged as an "80", it would be eligible for IHRA GT stock, which opens up even more potential engine combinations. Just some food for thought.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 10-09-2008, 01:02 PM   #6
bobby
bobby's Avatar
Don't know about a couple of years ago, but I think he is running a Buick in it now. Think the car is a 78.
Old 10-09-2008, 02:38 PM   #7
Chuck Garey
Liked 10 Times in 7 Posts
Tony has always ran a 455 buick in his camaro in SS (with 9" tire and no brake I might add) always top ten qualifier.
Chuck Garey is offline   Reply With Quote
Old 10-09-2008, 03:24 PM   #8
bobby
bobby's Avatar
Knew I wasn't to far off.
