Liked 133 Times in 76 Posts
I have a T350 behind a small block in my 3rd gen Camaro. What trans shield will fit? I've got a CSR, both the form fitting one and the one that goes at the rear section. There is no way the form fitting one will fit with a stock floor pan and firewall that I can see. Tell me if you can get one to work. The rear shield will go in but it's going to take some work around the shift cable and my header collectors. It sure is tight under there!
I run a TH200 but no shield, all I can say is good luck!
Liked 201 Times in 52 Posts
I have some friends having the same issues and looks like a blanket is the way to go. Some nice blankets out there today in a couple different lengths.
The more people I meet the more I like my dog Kevin |
hey Kevin, what brand of blankets are you referring to? I have the same space issues, trying to use a TH400 in a '65 Chevelle. A really small tunnel since they used PG's only.
When using a blanket, what's everyone's opinion on clearance for the shift cable? Sorry if I steered us off course. thanks, Ken |
#5 | |
http://www.homedepot.com/p/1-in-Rubb...7795/100160272
I tried the metal CSR shield and I can get it around the trans. The shift cable is where I'll have a problem and at the Rt. header collector. I'll need to order a shift cable bracket to modify and i think it will fit with some modifications.
I didn't want to wrap the trans in the blanket, but I do have one to try. I figured the shift cable would be a problem with the blanket also. |
