Liked 227 Times in 74 Posts
What is the best method for flushing the cooling system at home? Trans builder said to flush the system after finding debris in my trans.
J.T. Rose & Associates U/SA T/SA 302R |
#2 | |
Liked 1,914 Times in 429 Posts
Most parts stores carry "Cooler Flush", usually, two cans will do the trick to flush a transmission cooler.
Alan Roehrich 212A G/S |
Liked 920 Times in 259 Posts
Kooler Kleen
Liked 1,268 Times in 354 Posts
I don't know if this is good or bad, but historically, I've just sprayed a bunch of brake clean through the lines and blown them out with an air hose. Makes a mess but gets the job done.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
#5 | |
Liked 210 Times in 91 Posts
Trans guy wants you to flush the transmission fluid cooler in the radiator or wants you to flush the antifreeze? If you have debris in the transmission fluid cooler side of the radiator some times it is best to install a new radiator. Ray
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
Liked 1,958 Times in 593 Posts
I dont know anyone running a cooler on a race car. I never have.
Mike Pearson 2485 SS |
#7 | |
Liked 348 Times in 152 Posts
A plate and fin type cooler should be replaced, tube style can be flushed. Either one, WAY cheaper than another trans rebuild because of recirculated trash.
Phil Molski PMR Performance S/C 1623 |
