Old 07-12-2025, 10:27 AM   #1
Dennisdallas188
Liked 6 Times in 3 Posts
Default Dedenbear Lighting Plus L2 Help
Hello, we have an '88 BOS chassis with a 700HP SBC engine & shorty powerglide trans. The L2 came with the chassis and we've got it set up and functioning for Pro Tree, Super Comp, however when I press the button for full tree mode I have problems.
For full tree I'm trying NOT to use the throttle stop and just rely on the "chip" or starting line and burn out RPM control. How do I shut off the throttle stop function in full tree?
Dennis
We are brand new to racing so all help is appreciated.
Dennisdallas188 is offline   Reply With Quote
Old 07-13-2025, 10:11 AM   #2
SST159
Liked 20 Times in 16 Posts
Default Re: Dedenbear Lighting Plus L2 Help
Dennis,
Go on their website and select the product you are using Lightning 2 Plus. you will see a link to down load the instructions.
Hope this helps.
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 07-14-2025, 05:30 PM   #3
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 226 Times in 97 Posts
Press the 'STOPA' button repeatedly to cycle through the various timers. Make sure all of them are set to 0.000.
Alternatively, on the last screen of the cycle, you can turn the stop OFF completely.
Then do the same using the 'STOPB' button.
If you know which output your throttle stop is connected to, you only need to cycle through the options for the applicable timer.
https://www.mpsracing.com/instructio.../Lightning.pdf
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
