Old 06-10-2025, 01:17 PM   #1
Dirk Olson
Liked 172 Times in 46 Posts
Default T&E 48ft W/Lounge
Posting for a Friend T&E 48 foot $175,000
Trailer is about as perfect as you can imagine if you doubt it call Todd at T&E! Pictures are in the link below.
BILL RIEMENAPP
PHONE ? 608-792-5420
2003 T&E ENT AUTO HAULERS / ALL ALUMINUM GOOSENECK
10' LOUNGE / 48' OVERALL / 40' FLOOR / 3 AXLES
SERIAL# -1T9500V3531230568 / MODEL# - GNAA2A3 / DOM 05/2003 / GVW -19020
STANDARD EQUIPMENT:
LIGHTWEIGHT ALUMINUM EXTRUDED FLOOR/FRAME
.050 ALUMINUM WALL EXTERIOR W/ ALUMINUM UPRIGHTS
.040 1 PC. ALUMINUM ROOF OVER ALUMINUM ROOF BOWS
WHITE - STANDARD COLOR
102" WIDE - 81" BETWEEN FENDERWELLS
10 PLY RADIAL TIRES 16"
SPARE TIRE & WHEEL & HANGER - ALCOA ALUM. WHEEL
6' 9" INTERIOR HEIGHT
7000# DEXTER SLIPPER SPRING AXLES - 8 LUG HUBS
6 - 12 VOLT LOADING LIGHTS ON ONE SWITCH
48" SIDE DOOR W/ RECESSED LOCK
ALL ALUMINUM RAMP DOOR W/ SPRING & 2 RECESSED STAINLESS CAM LOCKS
BATTERY PAC
ALUMINUM FENDER SKIRTS
HYDRAULIC FRONT LIFT W/ POLISHED STAINLESS STEEL COVER
4 D-RINGS - LOOSE
GOOSENECK - BALL - 2 5/16" BALL
RADIUS, AERODYNAMIC FRONT END W/ POLISHED STAINLESS STEEL
STANDARD W/ 30" SETBACK ON FRONT WALL
ALCOA 16" X 7" ALUMINUM WHEELS
STEEL AXLE SUPPORTS AND STEEL TONGUE
ON-SIDE TURN SIGNALS
__________________________________________________ _________________________________
OPTIONS FOR T&E ALUMINUM AUTO HAULERS:
CHANGE STANDARD .050 ALUMINUM TO .090 ALUMINUM PLATE SIDES - RIVETLESS
INSULATE WALLS & CEILING WITH BLUEBOARD INSULATION
COVER INTERIOR WALLS AND CEILING WITH WHITE .040 ALUMINUM INCLUDING SHINY
ALUMINUM EXTRUDED WIRE COVER AT CEILING
54" DOUBLE SIDE DOOR WITH STAINLESS RECESSED CAMLOCK
8' INTERIOR HEIGHT - 117" EXTERIOR HEIGHT
30" RV DOOR ADDED TO TRAILER - WITH WINDOW
30" EXTRUDED SIDE DOOR STEP - TAKE OFF STYLE
54" EXTRUDED SIDE DOOR STEP - TAKE OFF STYLE
2 - 60" SPLIT REAR RAMP DOOR EXTENSION WITH HEAVY DUTY BUMPERS
FRONT ACCESS DOORS TO HYDRAULIC AREA UNDER UPPER DECK
13,500 BTU ROOF AIR WITH HEAT STRIP - 2
VINYL STRIP CURTAIN FOR SIDE DOOR - 48"
ONAN 10000 WATT QUIET DIESEL GENERATOR
NOTE: (ALL GENERATORS INCLUDE REMOTE START - HOUR METER -
AND EXHAUST.) INSULATED GENERATOR COMPARTMENT AND DOOR -
PLEASE NOTE: EXHAUST TO GO UP OUT TOP OF ROOF
FUEL TANK FOR DIESEL GENERATORS
AIR LINE PACKAGE INCLUDING 2 EXTERIOR AND 3 INTERIOR AIR OUTLETS
SLICK MOUNTS - 4
SPARE TRAILER TIRE HANGER - 1ST IS STANDARD
CARPET CIRCLES FOR BEHIND TIRES - 5 - 1 FOR SPARE
STANDARD ENGINE BEAM WITH TROLLEY - MINUS COME-A-LONG
HAND CHAIN HOIST FOR ENGINE BEAM TROLLEY
2 ARROW FLIP BENCHES INSTALLED INSIDE AND OUT - 4' EACH
SET OF PRO JACKS INSTALLED
48' X 12' ARROW AWNING RED IN COLOR - RAISED FRAME - BILLET QUICK CONNECTS
BLACK DOT FLOORING IN WORK AREA ONLY
TRAY FOR TOOL BOX ON ONE SIDE OF DOUBLE DOORS - TOOL BOX TO GO ON THIS TRAY
SHOCKS TO AXLES
10' X 8' X 30" WIDE X 36" TALL L-SHAPED WORKBENCH WITH STAINLESS STEEL TOP - WITH 1
RADIUS CORNER - WITH ROOM FOR LISTA CABINET - AIR COMPRESSOR AND GENERATOR
10' X 6' X 32" TALL X 16" DEEP TOP CABINET
CORNER COMPUTER CABINET WITH ROLL UP DOOR
1 - 2' X 2' X 4' CLOSET ABOVE LISTA CABINET
1 - 4' LONG X 16" DEEP X 32" TALL TOP CABINET BEHIND SIDE DOOR ON CURB SIDE
9' LONG X 6' TALL X 9" DEEP CABINET OVER CURB SIDE FENDERWELL -
WITH 4 DOORS AND 3 SHELVES
10' FUEL JUG RACK WITH CARPET ON WALL AND FLOOR ON CURBSIDE BEHIND
FENDERWELL
29" DEEP LISTA LOGISTIC CABINET - 6 DRAWER - 32" TALL X 30" WIDE
ELECTRICAL OPTIONS:
50 AMP FUSE BOX
FLUORESCENT LIGHTS - 4' DOUBLE TUBE COVERED - 4
SHORE POWER RECEPTACLE
EXTERIOR RECEPTACLES - 2
POWER CONVERTER - CHARGER
INTERIOR SWITCHES - 3
INTERIOR RECEPTACLES ? 4
QUARTZ FLOOD LIGHTS RECESSED INTO SIDE OF TRAILER AND MOUNTED IN AN ALUMINUM
BOX ? 3
AIR COMPRESSOR - 110V - 4 HP - 20 GAL TANK WITH RECEPTACLE AND SWITCH
12V BATTERY BOX - CABLES - AND BATTERY - WITH OPTIMA GEL CELL BATTERY - (1 EXTRA
TOTAL OF 2)
4500# WINCH WITH CENTER BLOCK
http://www.tande-racetrailers.com/us..._Gooseneck.pdf
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
