Old 06-09-2025, 02:19 PM   #1
Ken Kopecky
Liked 273 Times in 56 Posts
Default Chevy small block parts
I have for sale a used Gen 1 small block Chevy NHRA stocker cam that will fit a bunch of engines, years and car models. It?s the .390/.410? lift cam. From the research that I did, it will fit the 283, 327, 350, 307 and the 400 CI engines. The lobes are near perfect and it looks like there is very little run time on this piece. It came out of a 327 that was in a 68 Corvette stocker. It looks like it?s a Comp Cams piece but not 100% positive as it?s hard to read the numbers on the end of it. No lifters though. I would like to get $100.00 for it plus the shipping.
The cam has been sold.
I also have for sale a set of used stainless steel intake and exhaust valves that came from a set of AFR 210 SBC aluminum heads. They are in great shape, are clean and have been faced so are ready to use. The intakes are AFR-7258, measure 2.05?, +.100? length and have 11/32? diameter valve stems. The exhausts are AFR-7254, measure 1.600?, +.100 length and also have 11/32? valve stem diameter. I would like to get $150.00 for the set plus the shipping.
Valves have been sold.
I'm selling this stuff for a friend of mine.
Edison, NJ
rider1454@aol.com
ID:	72781   Click image for larger version
ID:	72782   Click image for larger version
ID:	72784   Click image for larger version
ID:	72785   Click image for larger version
Ken Kopecky is offline   Reply With Quote
