Old 05-16-2025, 09:25 AM   #1
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Default Meziere SBC Water Pump 396/427 BBC Crankshafts
Meziere SBC Black Electric Water Pump like new only used for run stand engine for about an hour total time. In box with Chevy outlet $250 SOLD
SBC 487X heads, came off running motor 1 valve stem top the rocker arm damaged slightly
Ported by local circle track racer for their rules screw in studs and guide plates. $500
2-396/427 steel Chevy Crankshafts $400 for one $300 for other both in good usable shape
400 SBC block 4 bolt mains, .040 over, ARP main bolts, number 1 cylinder needs a sleeve, block was machined and builder put wrong pistons in, error was caught early but cylinders will need rehone and the 1 sleeve, crank is a new Summit cast crank, SFI flexplate, $650
Located in Commack NY paypal or venmo accepted shipping is extra text for pics
Rich Boyle 631-461-6761
