Old 05-15-2025, 08:45 PM   #1
BryanB1972
Default Jerico trans, SBF Bell housing and other parts for SBC
Trans is SOLD: Jerico DR4 clutch assist, Mag case. Large 10 spline SBF input, Trans is brand new and never run.
34/16 low gear with 29/21 main drive set
2.93 1st, 1.84 2nd, 1.32 3rd and 1.0 4th
Trans has never even had oil in it. No shifter.
$3500 firm: Sold
Brand new never used SBF Lakewood Bellhousing with block protector plate. Some paint has flaked off on the trans mating surface, was mated to the Jerico up above. Never in a car so I am more than positive it would recertify no problem. $450
Brand New Mcleod twin disc clutch for SBF and large 10 spline, Complete clutch discs, presure plate, aluminum flywheel all brand new and never in a car. $750
SBC 1968 291 heads. never ported, valves sit high in the seats. $300
SBC Comp Cams Solid roller 630 lift 106 Lob seperation $250
SBC Stud Girdles missing one lock nut $150 Sts SBC heads
Chevy 12 bolt gears, All 3 sets are street gears.
4.88 $100
5.38 $100
6.14 $65 This set has a tad of surface rust, cleanable. I just dont mess with them.
3 Hurst and Mr Gasket V gate shifters. All need rebuilt/restored. No linkage. $550 for all 3.
email for picutes. I will accommodate asap.
BryanB1972 is offline   Reply With Quote
