Liked 5 Times in 5 Posts
Shipping is available
Will be coming to Charlotte and Joliet national events 2 New World Products SB Chevy Motown 2 blocks # 084010 std. cam 842 lifter bore 3.995 cyl. bore 350 main nodular main caps $3300.00 each TCI SBC/BBC lightweight 29.2 168T flexplate PN 399870LW, like new. Weighs 6.09lbs. Can barely see the contact patch on the starter ring. Original date was 1/19, but was only ran in the car for 2 races. Will need recertified. Excellent condition $300.00 Jesel Dogbone lifters LFD-44002 .842 Diameter set of 16 $500.00 Bryant LS Chevy crankshaft - used one season of about 50 runs - $2600 Stroke: 4.000 inch Main size : # 1 = 2.5587 # 2 = 2.5586 # 3 = 2.5588 # 4 = 2.5587 # 5 = 2.5587 Rod journals : 1&2 rods : 2.099 3&4 rods : 2.0889 6&6 rods : 2.099 7&8 rods : 2.099 Wet sump crank ( short snout ) 58 tooth reluctor wheel Bob Wt: 1745 3&4 rod journal ground by Shaft Tec. Carillo rods 6.1 rods (was used with Bryant crankshaft above) BE :2.2253 PE :0.9285 Length: 6.100 B Width : 0.938 $1000.00 Winberg SBC crank condition: NEW stroke: 3.496 main size: 283 chevy 2.300 rod size: 1.850 rod journal width: 1.800 bob wt.:1540 $3500 Oliver I beam 5.7 rods set of 8 - used one season of about 25 runs BE: 2.125 PE: 928 Length: 5.7 Weight each: 575 Grams $500.00 7" Converter - Dynamic. Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00 Jesel belt PN 31052 ? never used - in sealed package 68-Tooth, 27mm Belt Width, Fits .391 Raised Cam SBC - $100.00 Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $150 for set. ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00 ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter used $50.00 All new or excellent used condition Comp Pushrods (ALL 5/16 ends) 7.750; 3/8; .080 wall; QTY 15; used; $20.00 CV Products pushrods (ALL 5/16 ends) 9.150; 3/8 straight; QTY4; used 9.200; 3/8; straight; .080 wall; QTY 8; used; $15.00 for all 9.250; 3/8; straight; QTY 8; used; $15.00 for all Trend Pushrods (ALL 5/16 ends) 7.450; 3/8; straight; .135 wall; QTY 16; used; $30 for all 8.125; 3/8; straight; .135 wall; QTY 1; new; $15.00 8.600; 7/16; Double Taper; .165 wall; QTY 1; new; $15.00 9.150; 3/8; Double Taper; .135 wall; QTY 29; used but like new; $10.00 each 9.200; 3/8; Double Taper; .135 wall; QTY 13; used; 100 for all 9.300; 7/16; Double Taper; .165 wall; QTY 12; used; $100 for all 9.300; 7/16; Double Taper; .165 wall; QTY 4; new; $15.00 each 9.300; 3/8; Double Taper; .135 wall; QTY 11; new; $15.00 each 9.375; 7/16; Double Taper; .165 wall; QTY 12; used; $100.00 for all 9.375; 7/16; Double Taper; .165 wall; QTY 2; new; $15.00 each 9.400; 7/16; Double Taper; .165 wall QTY 18; new; $15.00 each 9.400; 3/8; Double Taper; .135 wall; QTY 11; new; $15.00 each 9.400; 3/8; Straight; .135 wall; QTY 8; used; $15 for all 9.450; 3/8; Straight; .135 wall; QTY 8; used; $15 for all JRI 2010-2015 Camaro front struts $350.00 used. Lingenfelter billet steel LS block girdle, No hardware $500 2 GM truck oil pans (1999-2006) pan only $50.00 each superstock@live.com for any questions or pictures shipping available for most all items. Paypal, check, or cash in person
Jeff Myers SS3254 S1522 |
