Old 02-23-2025, 09:16 AM   #1
Mike Walter
Liked 46 Times in 4 Posts
Default 1968 250/253 qjet combo 327 SS engine
NHRA 327 Superstock Engine. Factory rated at 250/ NHRA rated 253. 1968 only combination with Qjet carb only. This engine was completely fresh at INDY 2024 and has 10 runs on it. New crank, new Molnar Rods, new JE pistons with total seal diamond lapped rings, New Manley Valves, New PSI valve springs. Has Jesel .937 keyway lifters, roller bearing cam bearings, Dart SHP Pro Block, Jesel belt drive, Jesel front drive distributor. Manton pushrods, Stewart oil pump, Heads Up/ Hettler cylinder heads, Ron Hutter Intake manifold. This engine went .87 under (10.58 on an 11.45 index) at Indy with 3500 DA in my car and won class in GT/OA. Engine is being sold manifold to pan/ no carb. Must use a Qjet with this combo. Included in the sale is a spare Shaftech forged crank balanced for the components in this engine (new), a set of #293 bare castings, (1) Heads up cylinder used casting (#290 needs work but usable), several spare jesel rockers, lifters, springs, and pushrods specific to this motor. Does not leak water.
24,000.00 330-464-9231
Mike Walter is offline   Reply With Quote
