Old 02-16-2025, 09:03 AM   #1
richie 2
Liked 205 Times in 93 Posts
Default RPM ?
95 camaro, 3200lbs roughly, 350ci/3sd/auto, 5.13 gear. 10.5x30 tire...what rpm will that be in the 1/8th mile? tks for any suggestions,,,
Old 02-16-2025, 10:19 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: RPM ?
not enough info for accurate answer but based on what you provided, 6400 rpm max
Old 02-17-2025, 04:40 PM   #3
richie 2
Default Re: RPM ?
thankyou
Old 02-24-2025, 07:29 PM   #4
Steve Grady
Steve Grady's Avatar
Liked 170 Times in 55 Posts
Default Re: RPM ?
Go to TCIAUTO.Com On their web sight they have a section for Tech Center, Click on that and then go to technical resources. Then click on Racing calculators. You can figure any of the following 4 with 3 of the variables known.
Rear gear ratio
Tire diameter
Engine rpm
Miles Per Hour.
They have many useful calculators at the same place.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 03-07-2025, 02:22 PM   #5
chuck at gw
Liked 2 Times in 1 Post
Default Re: RPM ?
This formula requires knowing trap speed - which like, if you know that you probably already know what the rpm was:
RPM= (MPH?Gear*Ratio?336) / Tire*Diameter
chuck at gw is offline   Reply With Quote
Old 03-23-2025, 11:59 AM   #6
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
Default Re: RPM ?
WAG
60 Foot ET = 1.5245
330 Foot ET = 4.5285
1/8 Mile ET = 7.1393
1/8 Mile MPH = 93.8206
1000 Foot ET = 9.4059
1/4 Mile ET = 11.3265
1/4 Mile MPH = 117.8254
5660 RPM @ 660 - with some Converter Slippage
Stan
Old 03-23-2025, 12:09 PM   #7
Stan Weiss
Stan Weiss's Avatar
Default Re: RPM ?
You will need to adjust for converter slippage.
Equation (mph * 5.13 * 336) / 30
Value of mph Evaluated Equation
_70.00000 4021.9
_72.50000 4165.6
_75.00000 4309.2
_77.50000 4452.8
_80.00000 4596.5
_82.50000 4740.1
_85.00000 4883.8
_87.50000 5027.4
_90.00000 5171
_92.50000 5314.7
_95.00000 5458.3
_97.50000 5602
100.00000 5745.6
102.50000 5889.2
105.00000 6032.9
107.50000 6176.5
110.00000 6320.2
112.50000 6463.8
115.00000 6607.4
117.50000 6751.1
120.00000 6894.7
122.50000 7038.4
125.00000 7182
127.50000 7325.6
130.00000 7469.3
Stan
