Old 02-12-2025, 02:15 PM   #1
EAcunnin
Default M/W 12 bolt and front disc brake kit PPS shifter
Mark Williams Pro light weight assembly 12 bolt 4.88 light gears. 35 spline Hy Torque gun drilled axles, aluminum spool and yoke. M/W drilled rotors calipers,5/8th studs. Low runs fits 1968 to 1972 A- Body. $4000
Mark Williams Front Disc brake kit -75150 four piston caliper comes with spindles. Came off of A-body will fit early Camaros $1000 - Sold
Precision Performance Shifter Kwik-Shift 1 manual shifter black-polished
Three speed forward shift with cable and lever. Was used with 200 metric
$325 - Sold
Earl text 253-209-9129 location Arizona
EAcunnin is offline   Reply With Quote
Old 02-13-2025, 09:32 AM   #2
JRAIKES
Liked 17 Times in 5 Posts
Default Re: M/W 12 bolt and front disc brake kit PPS shifter
Where are you located
JRAIKES is offline   Reply With Quote
