Old 01-27-2025, 01:49 PM   #1
DBR Blaine
Default 496 Big Block
496 bbc tall deck
Engine was a new build 50 passes ago we used the engine as our back up and runs great. Runs 5.89-5.92 1/8 any day in a 3,000lbs car. The following is the parts list of what?s in the engine everything was purchased new in 2023.
Callies magnum crank 4.25
Eagle rods 6.535
Je pistons
Total seal rings
Comp cams camshaft
Cloyes hex adjust
Comp cams lifters
Moroso Billet oil pump
Moroso oil pan 7q
RHS intake
Harland Sharp rockers
Bare Skip white heads
Severe duty valves
Pac valve springs
Titanium retainers
$8200 located in Greenfield, IN
Engine has around 70-80 psi of oil pressure at idle with 20w50 vr1 and ran best at 38* and shifted at 7,200 our converter was around 6,000 stall.
DBR Blaine is offline   Reply With Quote
