Old 01-17-2025, 08:04 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default SBC, LS Parts New and used
Make reasonable offer for anything ? Shipping is available
2 New World Products SB Chevy Motown 2 blocks
# 084010
std. cam
842 lifter bore
3.995 cyl. bore
350 main
nodular main caps
$3300.00
TCI SBC/BBC lightweight 29.2 168T flexplate PN 399870LW, like new. Weighs 6.09lbs. Can barely see the contact patch on the starter ring. Original date was 1/19, but was only ran in the car for 2 races. Will need recertified. Excellent condition $300.00
Jesel Dogbone lifters LFD-44002 .842 Diameter set of 16 $600.00
Bryant LS Chevy crankshaft - used one season of about 50 runs - $2600
Stroke: 4.000 inch
Main size :
# 1 = 2.5587
# 2 = 2.5586
# 3 = 2.5588
# 4 = 2.5587
# 5 = 2.5587
Rod journals :
1&2 rods : 2.099
3&4 rods : 2.0889
6&6 rods : 2.099
7&8 rods : 2.099
Wet sump crank ( short snout )
58 tooth reluctor wheel
Bob Wt: 1745
3&4 rod journal ground by Shaft Tec.
Carillo rods 6.1 rods (was used with Bryant crankshaft above)
BE :2.2253
PE :0.9285
Length: 6.100
B Width : 0.938
$1000.00
Winberg SBC crank
condition: NEW
stroke: 3.496
main size: 283 chevy 2.300
rod size: 1.850
rod journal width: 1.800
bob wt.:1540
$3500
Oliver I beam 5.7 rods set of 8 - used one season of about 25 runs
BE: 2.125
PE: 928
Length: 5.7
Weight each: 575 Grams
$500.00
7" Converter - Dynamic. Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00
Jesel belt PN 31052 ? never used - in sealed package 68-Tooth, 27mm Belt Width, Fits .391 Raised Cam SBC - $100.00
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $150 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter used $50.00
All new or excellent used condition
Comp Pushrods (ALL 5/16 ends)
7.750; 3/8; .080 wall; QTY 15; used; $20.00
CV Products pushrods (ALL 5/16 ends)
9.150; 3/8 straight; QTY4; used
9.200; 3/8; straight; .080 wall; QTY 8; used; $15.00 for all
9.250; 3/8; straight; QTY 8; used; $15.00 for all
Trend Pushrods (ALL 5/16 ends)
7.450; 3/8; straight; .135 wall; QTY 16; used; $30 for all
8.125; 3/8; straight; .135 wall; QTY 1; new; $15.00
8.600; 7/16; Double Taper; .165 wall; QTY 1; new; $15.00
9.150; 3/8; Double Taper; .135 wall; QTY 29; used but like new; $10.00 each
9.200; 3/8; Double Taper; .135 wall; QTY 13; used; 100 for all
9.300; 7/16; Double Taper; .165 wall; QTY 12; used; $100 for all
9.300; 7/16; Double Taper; .165 wall; QTY 4; new; $15.00 each
9.300; 3/8; Double Taper; .135 wall; QTY 11; new; $15.00 each
9.375; 7/16; Double Taper; .165 wall; QTY 12; used; $100.00 for all
9.375; 7/16; Double Taper; .165 wall; QTY 2; new; $15.00 each
9.400; 7/16; Double Taper; .165 wall QTY 18; new; $15.00 each
9.400; 3/8; Double Taper; .135 wall; QTY 11; new; $15.00 each
9.400; 3/8; Straight; .135 wall; QTY 8; used; $15 for all
9.450; 3/8; Straight; .135 wall; QTY 8; used; $15 for all
JRI 2010-2015 Camaro front struts $350.00 used.
Lingenfelter billet steel LS block girdle, No hardware $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
superstock@live.com for any questions or pictures
shipping available for most all items. Paypal, check, or cash in person
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
