Old 11-24-2024, 09:24 PM   #1
WarrenC
Default New to .90 tech forum
I have read many current & older post to learn more about S/G & S/ST tech requirements for setting up an engine/car. As a newbie I did not want to flood the forum with basic questions. However I want to renew my drag racing participation on the right foot. No pun intended. The following is my current goals and existing chassis. Any input to this thread or in PM is greatly appreciated.
- Goal 800-1000HP N/A BBF 532/557 to compete in S/G S/ST. Builder suggestions?
- PG transmission - partial to Hughes open to suggestions.
- Current 11yr old chassis '88 Fox with QA1 front K-member & dble adjustable front shocks & cast / camber plates.
- Front motor plate
- 10 points cage. last cert.2003 @ 8.50. Will need new cert & upgrade to meet latest NHRA requirements. Chassis shop suggestions?
- Hotchkis adjustable rear control arms. pan hard bar. Is 4 link rear suspension the norm in S/G S/ST?
- 8.8 Moser 33 spline axles, 5 stud, Clip eliminators, spool 4.10
welded center section & Moser rear cover.
- ET fronts & 10.5 x28 MT
Great information in forum about Throttle stops, initial settings, electronics, shift type & differences & data acquisition. None of which I have experience with. Was just getting into delay box & TB when I packed it up.
Thanks in advance.
Warren
WarrenC is offline   Reply With Quote
