Old 11-08-2024, 12:08 PM   #1
Chuck Weissberg
Liked 57 Times in 27 Posts
Default Pontiac Iron Duke
I am wondering if the Pontiac Iron Duke 4 cylinder engine would be competitive in NHRA stock or SS class racing or is factored too high?
Chuck Weissberg is offline   Reply With Quote
Old 11-08-2024, 01:24 PM   #2
Billy Nees
Liked 7,909 Times in 1,754 Posts
Default Re: Pontiac Iron Duke
You might want to narrow that list down just a bit. There are a bunch of GM combos that use very different variations of the "Iron Duke" based on year and body style. Some are OK and some not so much.
Billy Nees 1188 STK, SS
Old 11-08-2024, 01:56 PM   #3
Jeff Niceswanger
Liked 1,071 Times in 378 Posts
Our fleet of Hyster and Yale forklifts at the plants had 181 cu in GM iron Dukes. Years before that they were 151 cu in GM dukes.
Jeff Niceswanger 3740 SS
Old 11-08-2024, 01:59 PM   #4
Billy Nees
The 181 was/is an industrial and marine variation. Check out the cylinder head if you get the chance, it's very good!
Old 11-08-2024, 02:37 PM   #5
Lyn Smith
Liked 1,002 Times in 203 Posts
The 62-69 Novas had a 4 cylinder option available. It was not called an Iron Duke.
Lyn Smith is online now   Reply With Quote
Old 11-08-2024, 02:42 PM   #6
Billy Nees
That would be the granddaddy of the "Iron Duke". Yac and I have brain-farted for years about doing a 4 cylinder 62-3-4 Chevy II 100 for W stick (Yac) or auto for years!
Old 11-08-2024, 03:32 PM   #7
FED 387
Liked 336 Times in 183 Posts
Bottom ends/main area of the 151 block are very weak along with the crankshafts being very spindly---heads are a problem with no flow u will have see what they allow as a stocker I would forget it as a SS it all depends on what they will let you get away with--and the carbs probably are lacking any thing to be used for performance---no support for the cam shafts only 3 bearings you need 5 to keep it from whipping around--- you will have to make or really scrounge around for any parts to make it work---if you never ran a 4 before its going to be a long learning curve to be successful-- FED 387
Old 11-08-2024, 03:34 PM   #8
Chuck Weissberg
Sorry for my stupidity....was looking at the 1986 151 cu in 4 cylinder.....don't understand why you are not a mind reader
Old 11-08-2024, 03:37 PM   #9
Chuck Weissberg
Thanks for all the feedback and input,,, saves a "bad" investment
Old 11-08-2024, 03:42 PM   #10
James Hill
Liked 14 Times in 6 Posts
I have a super duty block I would probably part with.
James Hill is offline   Reply With Quote
