Old 10-18-2024, 07:52 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default Parts cleanout - shipping available for most items
Make reasonable offer for anything.
2 New World Products SB Chevy Motown 2 blocks
# 084010
std. cam
842 lifter bore
3.995 cyl. bore
350 main
nodular main caps
$3300.00 each
TCI SBC/BBC lightweight 29.2 168T flexplate PN 399870LW, like new. Weighs 6.09lbs. Can barely see the contact patch on the starter ring. Original date was 1/19, but was only ran in the car for 2 races. Will need recertified. Excellent condition $300.00
Jesel Dogbone lifters LFD-44002 .842 Diameter set of 16 $600.00
LS Bryant crankshaft 4" stroke 58x - $2600
Carillo rods 6.1 rods (was used with Bryant crankshaft above)
BE :2.2253
PE :0.9285
Length: 6.100
B Width : 0.938
$1000.00
Oliver I beam 5.7 rods set of 8
BE: 2.125
PE: 928
Length: 5.7
Weight each: 575 Grams
$500.00
Winberg SBC crank
condition: NEW
stroke: 3.496
main size: 283 chevy 2.300
rod size: 1.850
rod journal width: 1.800
bob wt.:1540
$3500
8 ATI converter - Flashed 6500 behind 427/430 LS Combo Powerglide spline - $500
7" Converter - Dynamic. Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00
Wilson 4 hole aluminum tapered spacer. Dominator flange PN 024110 - $150 used for test only
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $200 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter used $50.00
CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends used but good condition $30.00
Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends used but good condition) $50
Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $150
Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25
Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25
Trend (qty 17) 9.150 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend 9.400 DBL taper .135 wall pushrods 5/16 ends (11) new $150
Trend 9.300 DBL taper .135 wall pushrods 5/16 ends (11) new $150
JRI 2010-2015 Camaro front struts $500.00 used.
Lingenfelter billet steel LS block girdle, No hardware $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
superstock@live.com for any questions or pictures
shipping available for most all items. Paypal, check, or cash in person
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
