Old 09-08-2024, 05:10 PM   #1
NHRA3106
Liked 147 Times in 38 Posts
Default ISO used aftermarket SBC block
Would like to find a used BowTie or Dart SHP block that would clean up at .040 over 4? bore?fairly local to Lexington, KY. Wouldn?t mind driving a few hours. This is for a bracket engine I have that started leaking water from a repaired sleeve in a stk block. Planning to use my rotating assembly, this is reason I need .040 over. May be a reach but wanted to check. Call or text 502-316-4667 Kevin Wells
NHRA3106 is offline   Reply With Quote
Old 09-08-2024, 07:54 PM   #2
nickh
nickh's Avatar
Liked 692 Times in 205 Posts
Default Re: ISO used aftermarket SBC block
Kevin if you get the Dart SHP block I have oil restrictors for the block if you think you need them. You can PM me..
