Liked 711 Times in 205 Posts
Adding 150lbs is a little harder than I thought. I have to separate it into permanent weight with a welded nut, removable weight bolted to frame/ chassis and a weight box for adjustment. Before I go through all this how much ET difference am I looking at with a low 10 sec. big block car? I would imagine the 1/10 per hundred is not the same for every combo.
Mike 7570 A/SA |
