Old 08-05-2024, 02:19 PM   #1
Cody Phillips
Liked 41 Times in 15 Posts
Default Super stock engine and converters
?2015 Camaro 376LS combo
Taylor built
Manley rods Gibtec pistons 4.130 bore comp cam .9 ring set Manley crank CFE heads pac springs and crower rockers GMR performance aluminum block have an elbow with eldebrock Intake. Throttle body to pan with coils, plug/wires, water pump, and fly wheel.. Literally has less than 35 passes on it and probably only 10 of them at best are past the 1000?. Has only ran the comp cams break in oil in it
Ran GT/DA with it. Will go 8.90-9.0 with right gear/converter set up
Can ship $27,500
?brand new ultimate 7? billet Coan converter
Powerglide spline
Should flash 6800-7000 behind 730hp
$3000
?brand new A1 steel 7? converter
Powerglide spline
$1500
Both converters were built for combo above
Call text 9107851660
Email cdphillips1992@gmail.com
Phillips auto body Custom paint
Lumberton, NC
910-739-7171
Cody Phillips is offline   Reply With Quote
