Old 07-06-2024, 12:25 AM   #1
Jim Hawkins
Liked 115 Times in 35 Posts
Default stock, super stock, sbc parts, bbc motor, turbo start
sbc 441 super stock heads, nice heads complete, no leaks $2500
441 super stock heads 1 head has a small crack, make offer
350 sbc super stock short block, filled stock block, bushed lifter bores, cast crank, reworked stock rods, roller cam bearings, roller cam, jesel belt, head studs. Last ran in SS/HA about 1995. Professionally built nice condition older motor. $2000
327 stocker motor out of a F/SA 66 nova. Was in a older stock eliminator car I bought. Ran just off the index with a glide. Pulled 1 head to inspect, .030 over lunati pistons, filled stock block, bushed lifter bores, cast crank, stock rods, 041 heads, q jet intake. $2000
420" BBC modified motor, built in 1989, 4.31x3.6, bow tie block, crower 4340 destroke crank, alum. rods, gas port pistons, jesel belt, hamburger alum. pan, innovators west balancer and crank trigger, alum. bow tie heads by lingenfelter, crane rockers, stud girdle, cast tunnel ram with tops for dominators or 4150 carbs.
Last ran in 1990 went 9.59 at 3320# with a glide in SS/BM.
Very cool nostalgia motor, 1989 Mile High Nationals Winner! $5000
2 holley dominators with linkage off of above motor. $1200
16 volt turbo start charger $200
2 Q jets off of sbc stock and super stock motors, $300 each
303-906-4065 Jim
proliftcolorado@aol.com
Jim Hawkins is offline   Reply With Quote
