Old 04-20-2024, 10:18 AM   #1
Woodfin
Liked 288 Times in 109 Posts
Default Discussion about E85
Racers, specifically those of you running E85. I want to learn more and am considering running it in a SBC, 383, high compression, trailered, dedicated drag race car.
Or, in your experience, is Methanol a better choice.
In reference to consistent ETs which fuel, E85 or Methanol holds the biggest advantage? Which fuel hold the best potential for winning because of consistent performance.
Larry Woodfin
Old 04-20-2024, 05:01 PM   #2
Jeff Stout
Liked 708 Times in 285 Posts
Default Re: Discussion about E85
I listen to alot of no prep guys and they use E85. It's here at the pump. The problem is it could be when testing at pump could range from75 to 82. That's the highest in AZ.
I know Vp sells it and is the all the rime. I'm guessing the difference at the pump could be why it's inconsistent.
