Old 01-07-2008, 10:41 AM   #1
njk53
Default Rear End Gear Lube
What is the best rear end lube to use? Is there something out there that is better in the viscosity department over the conventional gear lubes?
Old 01-07-2008, 11:21 AM   #2
SSDiv6
Default Re: Rear End Gear Lube
Redline or Amsoil.
Old 01-07-2008, 12:30 PM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Amsoil is most likely the best ..but Mobil 1 works good & you can pick it up @ any of the "chain" autoparts stores.
Old 01-07-2008, 01:48 PM   #4
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
We just run the Mobil1 off the shelf at AutoZone. Cheap, but it works.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 01-07-2008, 04:35 PM   #5
davyjones
lubrication engineers
davyjones is offline   Reply With Quote
Old 01-07-2008, 06:16 PM   #6
Myron Piatek
Liked 138 Times in 51 Posts
Thumbs up Re: Rear End Gear Lube
I use Amsoil also. Their best, thinnest stuff is SEVERE GEAR? Synthetic Extreme Pressure (EP) Lubricant 75W-90 (SVG) which I use in both, the race car and tow truck.
Amsoil source and info page:
http://www.thelubepage.com/
LOCOMOTION Racing
Old 01-08-2008, 12:40 AM   #7
Ray Menard
Ray Menard's Avatar
I run a 9" Ford with 6:20 Gears @ 9800 RPM (1/4 mile). I use Lubrication Engineers Gear Lube 607 ALMASOL (ISO VG 220/SAE 90/AGMA 5EP). Roger Lamb carries it. Any lube will do a reasonable job, however, I settled on the ALMOSOL by using this simple test:
On a Test N' Tune day, with your current lube in the case, make a pass
After your 2nd pass of the day (to account for heat-sink), safely pull off to the side of the "return" road
Using your Infra-Red Temp Gun, get a reading from the case
On the same day, change to your chosen replacement lube
Make your 3rd pass, pull off etc., etc.
The lowest temp reading indicates the best friction control.
Hope this helps.
Ray Menard
SS/CS (SS/DM & SS/EM)
#7386
Ray Menard is offline   Reply With Quote
