Old 02-05-2024, 02:56 PM   #1
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Default Stinnett or MaxSpeed
I am looking for input on a new stop for my new hotrod. I have limited hood clearance and do not want a scoop. So I have about 2" of available room under a carb for a stop. Looking for experiences with either. Pros cons etc. My last S/ST car had a disc stop buit they are limited in bore size and I am looking at no smaller than a 2.200" throttle blade. My engine actually made a fair amount more power with a 2.400...Any thoughts are appreciated.
sst7250 is offline   Reply With Quote
Old 02-05-2024, 03:24 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Stinnett or MaxSpeed
Al, everyone I knew that ran the MaxSpeed no longer does.
That said, I too have limited under hood clearance. I've been running a custom height 4150 stop from #1 Stop since we have first competed in S/ST.
Last season I swapped my 4150 carb to BLP's "large bore" 4150 which uses the same body as the twin blade. Once again I called onto Gary at #1 Stop who again built me a custom height stop that I will be using this season.
Old 02-05-2024, 05:56 PM   #3
Keith 944
Keith 944's Avatar
[QUOTE=1320racer;692752]Al, everyone I knew that ran the MaxSpeed no longer does.
Last season I swapped my 4150 carb to BLP's "large bore" 4150 which uses the same body as the twin blade. Once again I called onto Gary at #1 Stop who again built me a custom height stop that I will be using this season. End Quote]
You guys must want to be wearing that neck restraint this season! lol
As for my opinion, yes give Gary at number one stop a call. He also deals with Stennett stuff. really you can’t go wrong with him.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 02-06-2024, 06:07 PM   #4
ausby
ausby's Avatar
Liked 34 Times in 18 Posts
I got one from gary at #1 stop. super nice piece.
Ausby Brewington
A231 S/G
ausby is offline   Reply With Quote
Old 02-06-2024, 07:43 PM   #5
Regan Wilson
Regan Wilson's Avatar
Liked 134 Times in 70 Posts
As for my opinion, yes give Gary at number one stop a call. He also deals with Stinnett stuff. really you can’t go wrong with him.[/QUOTE]
I already bought by head and neck contraption. I don't plan on slowing down. It's going to be a PITA for sure. By the way if any of you see me struggling with this **** give me a hand please.
Regan Wilson is offline   Reply With Quote
Old 02-06-2024, 07:54 PM   #6
Keith 944
Keith 944's Avatar
lol I feel the same way I bought two, knowing I would forget to bring it with me if I was using the other car that day.
I have watched people have to have somebody else help them buckle the straps or whatever, a lot of these races I am by myself not looking forward to this!
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 02-07-2024, 01:34 PM   #7
sst7250
sst7250's Avatar
Stop is on the way. Thanks for the replies. I already have my head and neck restraint. Had to wear one in TS/heads up stuff for the last few years. FWIW I have a NecksGen RevII and I just leave it attached to my helmet, and prefer a helmet skirt to the head sock and have used both. Just coming back to S/ST after a 10 year hiatus or bump on the head. Will run when we can between heads up stuff. Thanks again.
Old 02-07-2024, 01:47 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Stinnett Stop for me . much better than the Max Speed. ATM also makes a very good stop.
Old 02-07-2024, 04:21 PM   #9
Phil S/ST
Liked 34 Times in 14 Posts
Who has the go to carb? Stinnet, APD, ATM..?
Phil S/ST is offline   Reply With Quote
Old 02-08-2024, 06:37 AM   #10
1320racer
1320racer's Avatar
ATM
