Liked 5 Times in 5 Posts
Tilberg low compression 350 shortblock
Crower 5.7 rods 2.125 with .875 pins BME pistons, total seal rings Crower crankshaft Crower 903 tie bar lifters with .810 wheels comp cam $6500.00 Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $400 for set. ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00 ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter – used $50.00 CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends – used but good condition – $30.00 Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends – used but good condition) $50 Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $150 Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25 Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25 Trend (qty 17) – 9.150 DBL taper .135 wall pushrods 5/16 ends (used good) $35 Trend 9.400 DBL taper .135 wall pushrods 5/16 ends (11) new $150 Trend 9.300 DBL taper .135 wall pushrods 5/16 ends (11) new $150 JRI 2010-2015 Camaro front struts $1000.00 used. 1 – Lingenfelter billet steel LS block girdle, No hardware $500 2 GM truck oil pans (1999-2006) pan only $50.00 each Jesel Dogbone lifters LFD-44002 – set of 16 – 1500.00 LS Bryant crankshaft – 4” stroke – 2800 Carillo rods 6.1 rods - 1200.00 ATI/Coan converter This converter was manufactured by ATI, but freshened and rebuilt by Coan. Turbo spline, 8" steel with Square cut L Stator (35 degree), C Pump. We never ran this, but previously was ran behind a 255HP 350 combination. $500 ATI converter Flashed 6500 behind 427/430 LS Combo – 8” Powerglide spline - $500 7" Converter - Dynamic. Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00 Wilson 1” 4 hole aluminum tapered spacer – Dominator flange PN 024110 - $150 used for test only MSD - Ford HEI Distributor cap and hold down PN 8408 NEW - $40.00 Energy suspension Poly engine mounts for SBC PN 3.1114G NEW (pair) $75.00 Biondo RPM2 shift controller – 2 LCD bars are inactive, but still legible to program - $100 SBC Polished fabricated valve covers with baffles tall - $100.00
Jeff Myers SS3254 S1522 Last edited by JeffM; 03-09-2024 at 07:55 PM. |
