Old 01-13-2024, 10:48 PM   #1
Jim Cimarolli
Liked 166 Times in 46 Posts
Default 1970 402-375 Stocker Motor
'70 402-375 Stocker Motor. 1971 4 bolt main 454 block, sleeved back to 4.185 bore. The block is not filled. Lifter bored. Steel GM crank, dimple rods, JE pistons, Comp Cam, Shubeck lifters. I never broke one, but I never used a 2 step. Stefs Oil Pan, the newer 291 heads, 359 intake manifold, ATI lightweight Super Damper. Cylinder Heads were new out of the box, no acid, no grinding. This engine will go through an NHRA tear down with the piston out. Made 604 horse on the dyno. Went 10.20's in my B/SA Nova @ 3460lbs. It has about 50 runs on it since it was freshened. $7,500. I am in Sulphur Springs Tx. PM me if interested.
Jim Cimarolli is offline   Reply With Quote
Old 01-18-2024, 12:47 AM   #2
Jrh5220
Liked 30 Times in 19 Posts
Default Re: 1970 402-375 Stocker Motor
604 with iron heads is impressive, if you need one buy it!
Jrh5220 is offline   Reply With Quote
Old 01-29-2024, 03:43 PM   #3
leonard trahan
Jim I'm interested in your stock eliminator engine can you give me a call .
Leonard Trahan 832-499-3431 I race in division 4 , 417B
leonard trahan is offline   Reply With Quote
