Old 12-17-2023, 07:46 PM   #1
John Osborne
John Osborne's Avatar
Liked 75 Times in 17 Posts
Default 1970 Buick GS Stage I Stock Eliminator
This is the car in my avatar.
Runs B, C, & D/SA. Currently running C/SA @ 3635 lbs.
Clear title
Comp cam, Trend lifters, T&D roller rockers, ATI damper, Hays SFI flywheel
Diamond pistons, Total Seal ring package, Crower/TA rods, Clevite bearings
TA front cover and oil filter adapter, Canton oil accumulator
Engine spec sheet
MSD distributor, wires, and 7530T ignition box
Jason Line Q-jet
Magnafuel Quick Star 300 fuel pump with MP9945 return style regulator
Stainless steel “Headers by Ben” (Ben Line)
ATI MRP Treemaster converter with Scott McClay TH200, JW UltraBell
DTS 12 bolt housing with TA girdle
Mark Williams aluminum spool with 3.250” carrier bearings and gun drilled axles.
AFCO double adjustable shocks, front and rear
Received the front shocks back from AFCO today (1/12/24). They rebuilt them and revalved the compression.
Wilwood disc brakes, front and rear, with dual caliper rear
Weld AlumiStar wheels
10 point chrome moly roll cage
Powermaster starter and alternator
XS Power 16 volt batteries and charger-Flaming River battery switches
Painless Performance toggle switch panels
Griffin aluminum radiator-dual electric fans, Meziere electric water pump
RJS 5 point seat belt harness certified to June, 2026
RacePak V300 data logger
Computech log book
Toshiba Satellite lap top computer to use with RacePak and MSD 7530T ignition
On my PC, I have done a Word program telling what has been done to the car. Including brands of parts and part numbers. It is six printed pages long. This is great information and will save guesswork for the next owner.
Best 1/4 mile run this year; Beech Bend 10.473 @ 125.38. Index 11.40
Best 1/8 mile run this year; Ohio Valley 6.543 @ 102.19. Index 7.32
$50,000
Call 270-234-4259 (No texts please) If no answer, please leave a message and I will return your call. 8am-8pm EST
Can Email photos, address is jop455@aol.com
PM - OK
Thanks, John
John Osborne is offline   Reply With Quote
