Old 12-10-2023, 03:44 PM   #1
MDadas
Liked 5 Times in 4 Posts
Default 1989 Pontiac Firebird Super Stock GT Car For Sale
Built into a racecar in 1990
Beautiful Chromoly Tig Welded Cage
4 Link with a fresh 12 Bolt with Mark Williams Axles and Spool
Brand new 5.86 Pro Gear and Moser Rear End Cover
313/295 350 Super Stock engine
Filled 010 350 Block
Heads Up Heads
Heads Up Intake
Headworth QuadraJet
Jesel Belt Drive
Jesel Rockers
Jesel Front Mount Distributor
Lunati Cam
BME Pistons
GM Rods
GM Crank
Moroso Pan
MSD Crank Trigger
ATI Balancer
New Electric Water Pump
1.98 First Gear Powerglide
A1 7 inch Converter
Lamb Shocks and Struts
Lamb Brakes
MSD 7AL2
MSD Two Step
ACD RPM switch
Hurst Shifter with Air Solenoid
Air Bottle and Regulator
All Autometer Gauges
Brand New MagnaFuel Fuel System, Pump, Regulator and Lines all the way through
2 Brand New 12 Volt Batteries
Nice headers
Mickey Thompson Wheels
Brand New Mickey Thompson tires all the way around
31.25 Super Stock Radials
27.5 ET Fronts
The Interior is show car quality!
The paint is beautiful and the underside of the car is just as clean as the outside.
One of the nicest cars I’ve ever owned.
In GT/HA at 3200 pounds it went 10.27 at 128 with 6 quarts of 5W20 Oil in the heat! Not the fastest thing out there but will qualify and is reliable.
Comes with a spare block, 2 cases of oil and also Fuel Factory race gas!!! Come get it and go to the race track or buy as a roller and put your choice of combination in it. $28,500 Turnkey. $24,000 Rolling No Motor or Trans. Have tons and tons of pictures. Call or text Matt Dadas at 440-396-0568. Thank you for looking!
MDadas is offline   Reply With Quote
