Old 11-23-2023, 11:21 AM   #1
FSA1673
Liked 12 Times in 6 Posts
Default 1968-1972 GM A Body Bump Steer Kit
Anyone make a bump steer kit for this type of chassis that raises the outer tie rod. All kits I can find seem to lower the outer tie rod. Based on my measurements I need to raise the outer tie rod about 0.5 inches to reduce bump steer.
FSA1673 is offline   Reply With Quote
Old 11-23-2023, 11:28 AM   #2
SSDiv6
Default Re: 1968-1972 GM A Body Bump Steer Kit
Lots of choices:
https://www.speedwaymotors.com/Modif...SEGOOGLE&nis=6
https://www.umiperformance.com/home/...-adjuster-kit/
https://www.trzmotorsports.com/produ...ck-steering-4/
Old 11-23-2023, 11:36 AM   #3
FSA1673
Speedway motors kit is for a pinto type spindle.
All the other kits are designed to lower the tie rods from my understanding.
Old 11-23-2023, 11:40 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
what you need and want are anti dive bars, designed by Larry Pappas
Old 11-23-2023, 07:40 PM   #5
FSA1673
anti dive bars? You mean the cross shafts on the upper control arm?
Old 11-23-2023, 08:48 PM   #6
1320racer
1320racer's Avatar
yep
Old 11-28-2023, 11:35 AM   #7
FSA1673
https://www.cachassisworks.com/p-294...-aluminum.aspx
I guess these are legal. My outer tie rods needed to be raised to reduce bump steer. Already had the Weibe anti dive cross shafts.
Old 11-28-2023, 01:37 PM   #8
1320racer
1320racer's Avatar
I can't image why you are having a bump steer issue, I never did.
Old 11-28-2023, 01:54 PM   #9
FSA1673
Just trying to get every last thousand of ET out of it. Toe changes about 1/4" each side as currently set up from full compression to full extension. Wheels shimmy a bit when landing from wheel stand. Might be nothing there.
Old 11-28-2023, 03:31 PM   #10
SSDiv6
It looks like Global West also has its own.
https://www.globalwest.net/a-body-19...bumpsteer.html
