Old 09-22-2023, 11:32 AM   #1
Ok stocker
Liked 100 Times in 24 Posts
Default 1990 Goldrush trailer 48ft 27k
1990 Goldrush trailer gooseneck 48. Has big diesel gen big air compressor water tank diesel tank ac stereo . Trailer has pro awning full length. Has led light strips for under awning and is setup to have speakers outside and other lights. Has air plumbed inside and out has water plumbed outside. Has engine lift and changer. Airride was completely rebuild three years ago and tires were replaced. Very low miles. Performax trailers added a air compressor and switch so trailer could be pulled with a truck or toter.
Alcoa aluminum wheels. Trailer is inside 8’9” tall. It is lower under the motor lift and the engine changer. The side door has towel holder can holders and a fold out tool tray. The side step is all aluminum and full width of side door.
Upper cabinets work bench with upper and lower cabinets. More cabinets on passenger side. Half of the gooseneck area is storage it has a new Kenwood stereo and speakers. There is a winch for 9’ tall rear door. A winch for the engine lift or to pull car in and a winch for the motor changer. There are plugs inside and out. Trailer has hose reals for air and water outside. Trailer is set up so you can run generator off on board fuel tank or toter tank. I usually just run the toter generator and plug the trailer into the plus on toter. There is 8 ft irk bench with vice and two toolboxes. I am sure I missed some things but it is loaded. 37500 price reduced 35000. Reduced 27500
Located Arlington Tx.
Last edited by Ok stocker; 11-22-2023 at 06:24 PM. Reason: Need to sell quick lowering price
Ok stocker is offline   Reply With Quote
Old 12-26-2023, 06:41 PM   #2
Ok stocker
Default Re: 1992 International toter 1990 Goldrush trailer
Sold
