Old 12-30-2007, 07:25 PM   #1
CPOlesen
Default Carb Help
I did't know where to post sorry. I have a 8896 Dominator untouched. It has 88 jets in the corners and no PV it is a 3 circut meter block. It is on a 496 pump gas motor with a 454C edelbrock intake, Dart pro 1 heads 310 cc no porting, cam 660 lift 260 dur @ 1/2 110 lobe seperation solid roller, 2"headers. this will be in a 67 Camaro all Steel Street strip duty. I want to know if anyone has suggestion for my first start up for a no bog or stumble operation. thanks
CPOlesen is offline   Reply With Quote
Old 12-31-2007, 04:14 AM   #2
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: Carb Help
I usually see 92's squared on those, be sure to balance the front/rear idle speed screws and run it about 1/8th to 1/4 turn fat on the idle mix screws. .035-.037 shooters are usually ballpark.
The usual stuff, jet extensions, notched float, brass or Nitrophyl float in front, not a white plastic.
Watch out for a drippy metering block(s) if it's a fairly old unit.
Dave Goob Cook is offline   Reply With Quote
Old 01-02-2008, 12:39 PM   #3
CPOlesen
thanks dave i'll check it out
