Old 08-30-2023, 07:01 PM   #1
Ken Kopecky
Liked 273 Times in 56 Posts
Default Clean pr of Mopar 3418915 J-heads w/the 2.02 int valves
I have for sale a very nice, clean pair of Mopar 3418915 casting J-heads with the 2.02 intake valves. Great street heads. These heads have bronze valve guide liners, new OEM style valve seals and have been painted the Mopar Hemi-orange color. The area under both of the intake and exhaust valves has been smoothed so they don’t have that factory sharp edge thus getting better air flow. All threads have been cleaned and are perfect but there is one heli-coil installed on one of the end intake manifold bolt holes. The date codes are 0112 and 3481. In addition, a pair of new Fel Pro 8553PT head gaskets are included.
https://www.summitracing.com/parts/fel-8553pt
The valve springs appear to be aftermarket but I don’t know the manufacturer. Definitely not the OEM 340 red springs. I checked the valve spring pressures and with the installed height of 1.63” the pressure was 98 lbs. on the seat and at .500 lift the pressure was 298 lbs. Coil bind looked to be at 1.10” so these springs would be great for a cam lift of .480”. These heads are bolt on ready. I would like to get $375.00 for everything plus the shipping. These are heavy so the shipping will be crazy. Local pickup would be great or depending on location, I can meet part way for the cost of fuel and any tolls. I can also bring them to the PA Dutch Classic at Maple Grove in October.
Ken
Edison, NJ
rider1454@aol.com
ID:	68234   Click image for larger version
ID:	68235   Click image for larger version
ID:	68237   Click image for larger version
ID:	68238   Click image for larger version
ID:	68240   Click image for larger version
ID:	68241   Click image for larger version
Ken Kopecky is offline   Reply With Quote
Old 09-11-2023, 11:55 PM   #2
casrak7
Liked 3 Times in 2 Posts
Default Re: Clean pr of Mopar 3418915 J-heads w/the 2.02 int valves
I emailed you
casrak7 is offline   Reply With Quote
Old 09-15-2023, 08:49 AM   #3
hrs1326
Liked 19 Times in 10 Posts
sent you an email..
hrs1326 is offline   Reply With Quote
Old 11-02-2023, 03:57 PM   #4
Ken Kopecky
Sold!
