Old 08-29-2023, 02:18 PM   #1
Hefler
Liked 4 Times in 3 Posts
Default 283 Stocker engine/trans,rearend and etc. for 1957 Chevy.
If your looking for a easy and economical way to put your 57 Chevy or build a car to put into NHRA stock eliminator here you go..
More description in the photos link below.
This is for the complete engine, transmission/converter, shifter, complete Moser rearend.
The engine factory 220hp NHRA rated 215hp) is complete from carb to pan, dist., starter, flexplate , water pump and alternator…. Just put coil wire on and plug in distributor and go.
Powerglide trans with 2.18 low gear and A-1 torque converter with roller bearing tail housing.
Mid trans mount and rear trans mount.
Precision performance shifter.
Complete Moser 12 bolt with 5.86 gear, 35 spline spool, axles with 5/8 studs,1350 yoke,Moser disc brakes and driveshaft.
Rear leaf springs
Fenderwell headers with collecter tethers.
Car ran 12.84 on the 13.15 index (O/SA) but needs some tuning and possibly have the converter loosened up.
Low runs on everything.
Priced to sell at $14.5k For everything listed above Everything is still in the car.
Front and rear wheels/tires available as well.
Call/text 817 521-5333
For photos/detailedinfo please click on the link below.
https://www.racingjunk.com/stock-sup...-headers..html
Hefler is offline   Reply With Quote
