Old 08-27-2023, 11:38 AM   #1
mickeyem2
Default Max Wedge Mopar Intake Manifold
1963 Max Wedge Intake Manifold. Casting number 2402726-1. Unmolested with the exception of primary bores opened up for 1964 engine. Should still pass tech on a 62 or 63 with the small carbs. I can sleeve them back down if it's a concern. There is a small tooth sized chip on one of the driver's side primary bores. Does not affect performance (I have gone .88 under with this manifold on a 63 low compression engine in B/SA). All fasteners are included. $2,500.00 plus free UPS to lower 48.
ID:	68171   Click image for larger version
ID:	68170   Click image for larger version
ID:	68173   Click image for larger version
mickeyem2 is offline   Reply With Quote
