Old 08-25-2023, 05:41 PM   #1
rboyle
rboyle's Avatar
Liked 602 Times in 165 Posts
Default Parts cleanout gears, carbs, shifter, air shift
Cleaning out some of my parts from the Vega
1- Holley 3 barrel carb, mechanical secondary kit and squirter installed list 3916-1s $500
1- DaVinci Holley 750 4 barrel list 9379 1770 mechanical secondaries still has choke horn old C/ED carb $500
12 bolt gear sets used 4.56, 5.14, 4.88, $100 each
BBC Crank trigger set up MSD mount, transducer has a chip in the face from a rock but works good. $150
Hurst 1/4 stick 3 speed shifter and cable revers pattern T handle with button
$225
Air shift set up, bottle, regulator, timer, piston, bottle mount
$200
2 Qjet cores $100 for both
SBC stud girdle $75 sold
Stef’s aluminum breather tank $100
Moroso electric water pump drive kit $100
Dominator anti reversion plate $40
Open hole and 4 hole spacers for Holley, aluminum, phenolic, and wood. From 1/4”-2” hieght $50 each or best offer
Call or text Rich
631-461-6761 shipping is extra
