Old 07-30-2023, 09:40 PM   #1
AlkyPinto
Default SFI 25.4 Rolling Chassis Racecar 110" WB
25.4 SFI 7.50, 110” WB, triple frame rail MS rolling chassis.
This chassis has gone 7.30s @ 190 mph.
Currently has partial 72 Mercury Comet body mounted.
Easily adapted to fit many body styles with 110” wheel base.
Floor structure, SS tin & SS tunnel easily reused in other body styles.
Tubular A-arm, double adjust coilover front suspension.
Pinto/MustangII rack & pinion steering.
ProMod 4-link, wishbone, double adjust coilover rear suspension.
QuarterMax ProMod rear antiroll bar.
Wilwood under floor billet master cylinder.
Wilwood 4 piston caliper disk brakes all around.
Brushed stainless floor, tunnel, tubs & tin work.
S&W wheelie bars.
Stroud ProStock chute with CO2 push button assist.
54” Altered style adjustable rear wing.
JAZ aluminum seat & cover.
RJS window net.
20+ circuit electrical & fuse panel.
Over head switch panel.
Over head Mega 450 delay box.
Digital Dakota gauges.
Antenna & wired for RE 2way radios.
Wired for functional rear brake, reverse & running lights.
Winters CO2 air shifter & rpm activated switch.
Trunk mounted dual batteries & voltmeters.
Rear kill switch & charging posts.
Trunk mounted dual trans coolers & electric fan.
Stroud fire system on engine & driver.
JAZ 5 gal fuel cell.
Goodyear 16x32 rear slicks (1 damaged).
Goodyear 15x4.5 Front Runners (1 damaged).
Weld 15x14 rear wheels (1 damaged).
Centerline 15x4 front wheels (1 damaged)
This is very successful award wining chassis.
Current Worlds Fastest Comet.
IHRA ProAm Top Sportsman 2015 #3 in Division 3.
IHRA ProAm Top Sportsman 2015 #10 in the World.
IHRA Cordova ProAm 2014 Best Engineered.
Norwalk Halloween Classic Best Appearing.
$17,500.
AlkyPinto is offline   Reply With Quote
