Old 07-15-2023, 06:26 PM   #1
Gregg Luneack
Liked 225 Times in 30 Posts
Default Mopar parts
1-Turbo Action 069J converter, 727 trans $600
1- ATI 8" 727 converter, 6200 stall $600
1- Mopar tach drive distributor, RB engines $225
1- SET 63 Max Wedge low comp pistons, JE, 4.280 bore,with LY rods $450
1-Pr 273-360 Heavy duty , thick wall rocker shafts $120
1- New set of 8 Speedmaster I beam rods, 1.094 pin.426-440 std length $300
1-New set of Speedmaster cross bolt main caps,426-440 Mopar $150
1-used Mopar 2.75 gear set for a 904 trans, $250
1- 413 bare block, cleaned $200
1-#3870610 small block W-2 cyl head $125
1-426-440 steel crank,mag,index, stroke .013,fresh from crank shop $500
1-New 440 bare block, std bore $1200
760-630 9094,no text, plus shipping
Gregg Luneack is offline   Reply With Quote
