Liked 281 Times in 108 Posts
New, never started, still on assembly stand. Chevy LS 3 drag race or street/strip engine. *Built with a 6.0 truck iron block.
*Callies 4" stroke crankshaft *Callies rods *Diamond forged piston, flat top *Rotating assembly balance by Callies *Mahle rings *Mahle/Clevitte HP rod and main bearings *Durabond HD cam bearings *Melling race oil pump *Cloyes double roller adjustable timing set *Allstar front cover for use with distributor *Cam Motion custom hydraulic roller cam *Johnson race hydraulic roller lifters *Chevy LS 3 head fully CNC ported *Brian Tooley race springs per cam *LS rockers with CHE trunnion and bushing upgrade *Manton custom length 11/32 pushrods *ARP studs and bolts *Polished, tall valve covers *CID race intake with 4500 Dominator flange *ATI damper *LS 3 water pump NOTE: The engine can be equipped with two different oil pans per your need NOTE: It also can be equipped to run with EFI setup of your choice NOTE: It will run on pump 93 octane, E85, race gas, or Methanol. NOTE: To complete the package to race with a carburetor, you will need, distributor, plug wires, ignition control box, and carburetor. NOTE: To race with EFI, you will need the EFI system of your choice plus ignition coils. Last edited by Woodfin; 07-04-2023 at 12:00 AM. Reason: add price, $17,700.00 |
