Liked 529 Times in 76 Posts
I'm steadily approaching a "ready to buy mode" and I'm contemplating TWO combos.
I thought it'd be easier to ask questions about two combos to receive better, more precise information, instead of sprinkler heading thoughts and questions in all directions. Do the Fourth Gen, Camaro/Firebird owners have a hard time removing and installing their LT1/LS1s? I remember working for a shop, and we had to drop the K member for easier access. IF...I were to run a 68-72 Nova, is it possible to run it as another year, within those years, by simply swapping what? Asking because the rear side marker is the only dead giveaway when other trim pieces can be easily swapped out. I know the engine choice plays a huge factor in what class, but I'm mainly focused on the flexibility of a Nova's appearance.
7350 Stock Eliminator Quite possibly the only member to REDLIGHT their join date ![]() |
Liked 162 Times in 45 Posts
In race trim the motors can be changed pretty easy in the Camaros and Firebirds without even removing the hoods. Break the engine loose from the trans, pull forward a little, turn it 90 degrees and pull it out! Actually pretty easy.
Those novas are the most versatile race platform ever made. AA-W and every class in between. |
Liked 114 Times in 29 Posts
You do need to remove the intake manifold before removing/installing the engine in the 4th gen. You can remove/install without removing the intake if you cut the center section of the cowl out.
#4 | |
Liked 520 Times in 176 Posts
The rear tail lights (Nova Body ) are a little wider for the 1970 - 72 body. The front bumper has bigger turn signal lights that are amber instead of kinda clear from the 1968-69 body. The 1968 has the ignition key on the dash, 1969 -72 has the ignition key in the steering column. The 1968 has the short marker lights front and back. The 1969 has the same as 68 short rear marker light with a longer chrome bezel showing engine cubic inch's. the 1970 -72 has the long side marker lights. So there's some more food for thought, Do I think NHRA cares anymore about marker lights, I seriously doubt it at this point, but I'd make sure that the engine combination has all the correct casting numbers for its application. With the 1969 body you can run just about every engine that Chevrolet had in its line up except for the 396/325 engine. Also no 427's, but a 1970 you can get the 402/ 375 HP engine and that's a good engine combo. What you are considering is the very reason I went with the Nova body some 40 + years ago. Versatility in the same body platform, one draw back is putting a good size 9x30x15 tire under there is a little challenging, between back spacing and a little creativity you can make it happen, not impossible. Most of the stuff that fits a Camaro will bolt on to the Nova, without the Camaro price tag. So, I hope this expands you horizons some - Have a Good Day and a Safe 4th of July. Respectfully, Henry Kunz 1534 H/SA Nova |
Liked 2,362 Times in 559 Posts
Didn't they toss a Nova for claiming the wrong body a while back?
Daren Poole-Adams NHRA Stock/SS 2007 |
You are correct. I believe it was the chap from Europe that bought a west coast car with I believe a 402/375 that would fit AA if he claimed the correct year but he didn’t. Someone caught his mistake and he got tossed. There are a lot of nice combos for that Nova body style. And the car can get very light.
Liked 534 Times in 143 Posts
I have done it both ways on my 4th generation F body with a LT1. I find it a lot easier to take it out of the top if you use a Happy Hooker engine plate that bolts to the top of the intake. They work great and all you have to do is lift and rotate the engine slightly with the hood raised all the way without the hood struts attached.
#8 | |
Liked 226 Times in 97 Posts
But then someone else took that to the next step to note that there was no combo that fit AA/SA for the model year that was claimed.
Tony Leonard S/ST 56 S/C 53 |
Liked 1,607 Times in 584 Posts
Liked 272 Times in 108 Posts
The LT1 has been beat up pretty good (275/358) cause in the 90,s everybody built one. They are a modern car with torque arm rear suspension R&P steering etc,and they were fast! There are still some fast ones out there...but good luck running beside a 69 440 Barracuda in C/SA!
