Old 05-29-2023, 10:12 PM   #1
MDadas
Liked 5 Times in 4 Posts
Default 2 Engines For Sale!
362 Small Block Chevy Short Block For Sale. Built by Ron Hutter at Hutter Performance, fresh and ready to go.
Dart Little M Block 4.060 bore
Callies 3.500 Stroke Crank
Manley 6.000 inch rods
CP Pistons with Total Seal Rings
Comp Flat Tappet Cam
Comp Belt Drive with New Belt
Professional Products DLC coated lifters
Fluidamper Balancer
Cometic Head Gaskets
Engine is set up for a Dry Sump oiling system but can be converted to wet sump easily.
$5500
350 Super Stock engine from the early 2000’s. Has sat for a while so I’d recommend pulling it apart just to be safe. Paperwork I have with it says it has 54 runs on it but again, has been sitting. 295/350 if ran in Super Stock but could be run as a bracket combination also.
Filled 010 350 Block
Flat Top BME Pistons
Coated GM Crank
GM Rods
Dave Layer Heads Up 041 Heads
Dave Layer Heads Up Edelbrock Victor E Intake
Jesel Rocker arms
Titanium Retainers
3/8 Pushrods
Crane Roller Lifters
Crane Roller Cam
Jesel Belt Drive
ATI Balancer
Moroso Crank Trigger
Moroso Fabricated Oil Pan
$5500
If you have any questions send me a message, text or call at 440-396-0568! Also can deliver to any races coming up or even ship it. Thanks for looking!
MDadas is offline   Reply With Quote
