Old 05-24-2023, 09:46 PM   #1
Timothy Fletcher
Liked 83 Times in 5 Posts
Default 2016 Entegra Cornerstone
2016 Entegra Cornerstone (model:45K). 600hp/1950 torque Cummins, Allison transmission, Spartan chassis, 1.5 bath, 2nd owner. 15k miles, Onan 12500 generator (1k hours), (2) 2800 watt inverters, side radiator, (3) stage engine brake, power front sunshades, 20k hitch that has been fully welded and braced.
(4) slides, (3) 15k BTU low profile zoned AC units. Touch screen Bluetooth radio, color rear and side view cameras. Everything on this thing is power, interior day/night window shades, window awnings, Girard awnings w/LED lights, slide out trays, cord/hose reels, rear engine door, macerator w/electric gate valves. Again, everything you can think of is just the press of a button.
Inside amenities include central vac, led-lit electric fireplace, 3 tv’s w/Bose sound bar and home theater system, 1 outside tv w/Bose radio and speakers, key fab to control power door locks and outside cabinet locks, quartz countertops, porcelain toilets, porcelain tile shower, queen blow up air mattress front bed, king size main mattress main bed, ceiling fans and dim controlled LED lights all throughout.
150g fuel w/dual side fill, 100g fresh, 62g grey, 41g black, 15g DEF tank.
All (10) batteries are new in 2022, new inverter in 2023, entirely new Hadley air system in 2023, every tank and valve were changed from the Spartan factory in Michigan, new step motor as of this week, anything that the motorhome needed, it received. Great overall quality and well-built, just serviced and all fluids changed to be ready for the year. Have tons of pictures I can send. Clean title in hand, ready to go. $389,000. Call/Text/Message Tim at 585-314-2455. Thank you!
Here is a link to the Craigslist add with some pictures:
https://raleigh.craigslist.org/rvs/d...624993225.html
Here is a link to the brochure for the spec sheet from the factory:
https://www.entegracoach.com/uploads...Literature.pdf
Dan Fletcher Racing
Stock / Super Stock
1792
Timothy Fletcher is offline   Reply With Quote
