Old 05-18-2023, 07:03 PM   #1
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Default Spring Cleaning!
- Billet 8" Hays clutch with 4 used 18 spline 5135 disks. 168 tooth flywheel. 24.6 lbs assembly with disk $800
- ROBMC chevy starter with front pinion support. Corner of aluminum block has been notched for clearance but I never ran it. $300
- 60 amp mini denso alternator $50
ID:	67290   Click image for larger version
ID:	67291   Click image for larger version
Troy Henderson is offline   Reply With Quote
Old 05-19-2023, 06:57 AM   #2
396chevy
Liked 2 Times in 2 Posts
Default Re: Spring Cleaning!
Troy Check your PM folder
396chevy is offline   Reply With Quote
