Old 04-05-2023, 08:27 PM   #1
Gregg Luneack
Liked 225 Times in 30 Posts
Default Mopar Parts
1-Big block Turbo Action o69j converter $700.00
1-big block Schneider 8" 5800 rpm flash $700.00
1-440 steel crank, mag,index, stroke .013 $500.00
2- 413 standard blocks,cleaned ready to machine $250.00ea.
1- Mopar tach drive distributor,440 $200.00
1-set 273-340 thick rocker shafts $120.00
1- Turbo Action reverse manual valve body, 904-727 $150.
1- Pro Trans reverse manual valve body 904-727 $200.00
1- A-1 8" 904 small block converter, 5000 rpm stall $600.00
1-set New Goodyear Eagle frontrunner tires 28"x4.5" $ 350.00
1-New MSD 6-AL Digital ignition $200.00
8-New 360 Mopar, 4.020 JE flat top pistons & pins $ 375.00
Can deliver to Vegas, 760-630-9094, no text.
Gregg Luneack is offline   Reply With Quote
Old 04-06-2023, 03:55 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: Mopar Parts
the msd 6AL, is it the 6425 model?
