Old 12-22-2007, 09:23 PM   #1
Uncrated
Banned
Default For sale: Woodfin's 1970 Nova
New Chrome bumpers front and rear
New Global West bushings & shafts
New Moroso front springs
New CE front shocks
New tie rod ends and hardware [ball joints are good]
New lightweight steering column with removable steering wheel
New Grant steering wheel
All brakes new front and rear, new shoes, new cylinders,
new hardware, new hoses, new master cylinder. [four wheel drum brakes]
New copper core radiator
New Radiator fan [Hayden electric 14 ?]
Moroso solid front mounts
Two hoods, stock hood, and Harwood 4? cowl hood [bolt on]
Two sets of small block headers [both coated]
New carpet
New door panels
New windshield
New three tone, Red, White, and Blue paint
New K & R switch system
All wiring is new including custom, heavy gauge battery cables
New master cut off switch
MSD Digital 6 and matching coil
Custom dash with Autometer gauges
Drivers fan
Deist cam lock harness
Hurst Quarter stick [two speed]
Swing out side bar
Eight point roll bar
New driveshaft and u-joints
New trans & pinion yokes
New 4.88 Richmond Pro Gears
Moser spool and axles
Factory 12 bolt housing has been straightened and braced
New LPW aluminum rear cover
New Cal Tracs
New Calvert split mono springs
New Afco rear spring rollers
New Calvert/Rancho adjustable rear shocks
New Holley 150 HP pump
New Russell in-line filter
New ? fuel hose front to rear
5-gallon RCI fuel cell
New M/T wheels [4]
New Hoosier tires
This covers the major systems. During the buildup, every bolt, nut, screw, etc was removed, cleaned, replaced, or upgraded as the item required. The car has been raced five times in F/SA since all the above listed work was performed.
I offer this Nova for sale as a roller with the above listed parts. Photos available.
Priced at $16,900.00
Larry Woodfin
Kilgore TX
durafin@gmail.com
903-985-1162 cell
Uncrated is offline   Reply With Quote
Old 12-22-2007, 10:01 PM   #2
THE LEGEND
Default Re: For sale: Woodfin's 1970 Nova
Folks That is a great deal on an awesome car. By the way I have a 350/255 motor for sale that would fit nicely in that car.
Chip Johnson
THE LEGEND is offline   Reply With Quote
Old 12-23-2007, 03:23 AM   #3
Dennis424C
Dennis424C's Avatar
Liked 2 Times in 2 Posts
How much for the motor and what are some details on it.
Dennis "The Menace" Clark
424C Pro E/T
424C S/ST H/R S/G
Dennis424C is offline   Reply With Quote
Old 12-23-2007, 09:53 AM   #4
THE LEGEND
Not trying to HiJack Larry's post.
You can call me at 910-309-1760
Thanks
Chip
