Old 12-22-2007, 07:49 PM   #1
GaryGoFast
Thumbs up 9.00 Footbrake 72 Nova
Nova was backhalfed By C&F Race Car, NY
Car is a 4 link, Koni double adj shock, 40 spline gun drilled Strange axles, 4.56,9 inch, 4 wheel Wilwood disc, 14.5x32 Hoosier, 4.5 x15 Hoosier on front, Weld Drag Stars all around, roll down glass windows, hood, truck and bumpers glass. Stock front clip with notched K frame, fits any motor. Flaming River alum steering box, Koni spa 1 frt shocks with stops.
JA Performance built 516 Alky BBC GM Bowtie blk, Scat crank, BME alum rods, Dart 345 heads w/ Nextek springs, Hooker Super Comp 2 1/8 tubes to Flowmaster Scavenger Collectors to Dynomax 16x4 Racer Magnum mufflers, Dart Tunnel Ram with Enderle Birdcatcher,-1 Belt Driven Fuel pump, Jesel Belt Drive, Crane rockers Crane rocker restraints, MSD 7al2,MSD, Crank trigger, Leanout, Fuel shutoff, EGT, Ron Davis Radiator with fuel cell in front, [also comes with additional alum 4 core rad when car is used with gas. 5 gal fuel cell w/ BG 400 and #10 to front if switched to gas. Hood if blower used, 2 piece & scoop hood if used with 4500 dom on gas, driveshaft & crossmember for T-400]
Select Perf glide with Dedenbear case and Pro brake, Select 8" convertor, JW Flexplate, Turbo Action shifter, wheelie bar and parachute come with car but are not being used and are off car at this time. Car has run a best of 8.96@152 with a 1.30 60 ft leaving off an 1300 rpm idle. The car weighs 3200 with a 250 lb driver, Car needs paint, no rust, undercarriage immaculate.
email to: topstreet1@aol.com
$22,500
GaryGoFast is offline   Reply With Quote
