Old 03-31-2023, 09:52 AM   #1
Timothy Fletcher
Liked 83 Times in 5 Posts
Default 2001 Fleetwood American Dream
2001 (’00-’01) Fleetwood American Dream 40DDS 40’ diesel pusher. Upgraded 350hp/1050torque 8.3 Cummins, Allison transmission, Spartan chassis, 2nd owner.
Side radiator, 90k miles, (2) slides, 22.5” tires, air ride/air brakes, hydraulic levelers, Onan 7500 generator, (2) 13.5 low profile AC units, (2) furnaces, window awnings, slide out trays, outside tv/radio and speakers. 105g fuel w/dual side fill, 95g fresh, 65g grey, 40g black, 10g hot water, 50g LP tank.
Kept under a shelter for the last 12 years unless it was being used. Motorhome is in great shape, no leaks, no delamination, straight as an arrow. All fabric and counters are in great shape as well with no rips or stains. Washer/Dryer has been removed and made into a closet. Everything works as it should inside and out. Drives straight, tows great and the factory 10K hitch has been braced up more.
All tires are new in 2021, all batteries are new in 2022, new fridge, new main awning fabric, new water pump, belts, hoses. Recently had the generator pulled out and rebuilt at the suggested hours to the specs of the manual (8K). Replaced the hydraulic motor that drives the radiator fan as of last week because it started to drip on the concrete. It has had anything it needed immediately especially mechanically. Great overall quality and well-built, just serviced and all fluids changed to be ready for the year. Have tons of pictures I can send. Clean title in hand, ready to go. $49,000. Call/Text/Message Tim at 585-314-2455. Thank you!
Here is a link to the Craigslist add with some pictures:
https://raleigh.craigslist.org/rvs/d...605265490.html
Here is a link I found online to the spec sheet from the factory:
http://media.rvusa.com/library/fleet...candream_b.pdf
Dan Fletcher Racing
Stock / Super Stock
1792
Timothy Fletcher is offline   Reply With Quote
Old 04-10-2023, 08:59 PM   #2
Timothy Fletcher
Default Re: 2001 Fleetwood American Dream
Sold!
Thanks Class Racer!
Dan Fletcher Racing
Stock / Super Stock
1792
