Old 03-20-2023, 01:03 PM   #1
Jeff Lane
Liked 12 Times in 3 Posts
Default Engine Components, Transmission, Gears & More
Updated Parts List as of 3/20/2023:
Rocker arm systems for SB2 heads: NEW
· Jesel complete shaft rocker system for SB2 heads; aluminum solid body rockers 1.75 / 1.7 ratio, bars, stands, hardware. Complete kit: $1900
427 LSX engine parts:
· Coated pistons, pins, New stef aluminum oil pan and pick-up, beehive valve springs, retainers, keepers, rocker arms, pushrods, hyd. Roller lifters, camshaft: $1800 - SOLD
CP pistons for Splayed Valve head set of 8 / 4.157 bore x .866 pin diameter with total seal rings: $500
CP pistons for Wedge head 4.165 bore / 1.390 c/h x .927: $400
200 pushrods 3/8" 7.700 to 9.250 lengths: $50 set of 8 or $100 set of 16
Jesel .875 SB-2 tie bar roller lifters dyno time only. Perfect condition: $400
Swartz 100% Billet SB-2 Intake Manifold for single 4-barrell & carb spacer. Multiple record holder $6000 new: $2800 - SOLD
Meziere big block Water Pump, Black (11201-072): $375
Magna Fuel Pro Star 500 Fuel Pump (B-8613) w/ Magna Fuel 4-port Regulator (H-12899) and mechanical gauge: $550
CV Products Large Oil Filter Adapter (CV 748): $100
Splayed-Valve Stainless Headers w/ tether collectors: 1 7/8” – 2 1/8”: $2000
Gears, Converter Parts & Brakes:
Driveshaft / Chrome moly 51" center to center / 1350 spicer u-joints / 39005-U yoke used one race: $300
5.83 Ford 9-1/2" Gleason Ring and Pinion polished and lightened used / perfect shape: $1300
6.00 Ford 9" ring and pinion US Gear rem finished, cryo'd, lightened / NEW: $800
6.33 Ford 9" Tom's differentials ring and pinion / NEW: $400
Coan Converter Stators:
40/19 :$450
35/19 : $450
45/19 : $450
Mark Williams Rear Brake System: Complete Rotators (11 ½” Steel), Hats, Calipers 8101, and Caliper brackets (71013-C, 07-0745): $500
Wheels & Tires:
Pro Series Polished Circle Front Wheels w/ Hoosiers: Anglia Spindle-Mount, 17”x2.25", 22.0x2.5-17 Tires: $500 / set
Bogart Polished Rear Wheels: 15 x 14", 3” B.S., 5 x 4.75: $1000 / set
New RC Comp Polished Torx Rear Wheels: 15”x12”, 3” B.S., 5”x4.50”: $1100 / set
Electronics:
Complete Racepak V300 System with wiring and sensors: $1500 - PENDING
MSD Digital 7: $650
Please reach out to if you have any questions.
Jeff Lane
Hancock & Lane Racing
(206) 818-1804
Jeff Lane is offline   Reply With Quote
