Old 02-24-2023, 07:33 PM   #1
drgrcr1156
Liked 2 Times in 1 Post
Default powdercoat flexplate
Let me ask the question here since NHRA has not responded. I purchased a new SFI 29.1 flexplate and it came in powdercoated. I was checking the spec for another reason, and I see that it specifies "No Powdercoat finish". Granted, there is no real tech inspection, but I don't need the hassle should it ever happen. Did the spec change?
drgrcr1156 is offline   Reply With Quote
Old 02-24-2023, 07:59 PM   #2
Keith 944
Keith 944's Avatar
Default Re: powdercoat flexplate
Doubtful that would be an issue. It already has the decal. It was done by the manufacturer. however, I strongly advise sanding off any paint or powder coating at the crank bolts location: I have seen 2 chip off and then the bolts loosen up.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
